Attempting to upgrade our current ArcGIS Enterprise 10.9.1 system to 11.1 and also migrate to a new 2022 Windows Server OS. This is a base install where all the enterprise GIS components (Portal, Server, and Datastore) are installed on the single machine. Following the steps outlined in the blog post https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/migrate-to-a-new-machine-...
Steps:
1. Configure a new VM with Windows Server 2022 OS.
2. Installed and configured ArcGIS 10.9.1 on the server. Used Chef automation and configured the system along with federation.
3. Installed all the patches and updated on both the Servers
4. Took a full backup of the existing enterprise GIS using the WebGISDR utility.
5. Imported the backup into the new Server. The import process ran successfully with out any errors. All portal content is available, the hosted feature layers are accessible and can be visualized.
** Only issue is that the ArcGIS relational datastore does not validate and the Federation is broken.
I have attempted this process in three different environments and encountered the same issue.
Attached are the screen shots with the validation errors.
ArcGIS Server log message:
The connection property set was missing a required property or the property value was unrecognized. This release of the GeoDatabase is either invalid or out of date. DBMS table not found [GDB_Release]
Tried to unregister the datastore and reconfigure without any luck. Have an active support case with tech-support. Has anyone encounted a similar problem?
The error message logged doesn't make much sense as the GDB_Relase table does not exist in the database (New or the current functional enterprise GIS)
Any insights, troubleshooting tips or assistance will be greatly appreciated.
Thanks!
