Hello -
We have two federated 11.3 enterprise deployments on a Server 19 VMs. Recently, we rolled out ArcGIS Urban which necessitated the use of docker and containerization. However, our portal logs have stopped working. Has anyone found a way to get portal logs to restart?
Here are some key points in our review so far:
What are we missing here?
is this a high available portal setup?
No. One is a multi-machine deployment and the other is a single machine enterprise builder.
I hadn't found this yet so thank you! According to this post, the portal logs were still being generated. Ours are not on either deployment. I will attempt the clean logs process on Monday in case this helps us.
I attempted to run the portal logs>clean operation but it did not complete. I received this error below. Thank you, Bill, for suggesting this.
Code: 500
