Access Management based on SCIM v2 interface for Portal
5365
9
11-15-2018 08:09 AM
SchipholArchitect
We need a Access Management interface, based on SCIM v2 for separating the Identity en the Access management layers.
Portal has already support for the standards for Single Sign On:  SAML. This is for Identity management  (authentication).
Our security standards require to separate the Access management (authorization). THis is company wide implemented via the SCIM interface. All applications within our company are now required to have a SAML and a SCIM interface.
My request/idea is to implement this SCIM interface to Portal.
Basic workflow when working with SAML + SCIM:
  1. User is registered in Portal using his company Identity
  2. Portal can verify login using the trusted SAML interface between portal and the OpenID/ADFS server using SAML
  3. This way user can log in using Company Identity
  4. Groups are created in Portal
  5. Groups are synced with Accessmanagement (IAM) using SCIM
  6. Groups are filled with the authorized Identities within IAM
  7. Filled Groups are synced with Portal
  8. Logged in user can access the authorized groups.
1 - 4 are now in place.
5 -7 have to be implemented using new SCIM v2 interface.
SCIM v2 is an open standard, and worldwide.
System for Cross-domain Identity Management - Wikipedia
SCIM: System for Cross-domain Identity Management
9 Comments
SchipholArchitect
Above examples include groups. It must also include roles/licenses (lvl1/lvl2 with the new names for Creator, Fieldworker etc..) and the special licenses (arcgis pro, navigator, etc..)
JörgHeidemeier
To manage user identities in cloud based applications and services easier we need an access management interface base on SCIM V2.
The idea is the same as already mentioned in the idea https://community.esri.com/t5/arcgis-enterprise-ideas/access-management-based-on-scim-v2-interface-f...
We need that for groups and roles.
Martin1
We would also need this functionality.
ChrisPVella
Strongly support the integration of SCIM for user and group provisioning. This is a core feature and requirement of our other enterprise applications, so would be good to see this developed.
ChrisPVella
John_Spence
I support this one too! Enterprise needs to support modern Enterprise IT tools for IAM.
pheede-esri
pheede-esri
Status changed to: Closed
John_Spence
In case anyone needs it, here is a user management script that can be extended to give you near SCIM capabilities. It's not perfect, but it was the solution I came up with to deal with the user issue.
https://github.com/wagisdev/AGOLPortalUserManagement
