Hi all, hoping someone can help troubleshoot. I've got a workbench that I'm using to hopefully publish ongoing updates from publicly hosted Get It Done reports for San Diego. I'm running into this error with the 2021 YTD dataset:
ArcGIS Portal Feature Service Writer: String attribute 'public_description' truncated to fit maximum field length of 254 on server
... Last line repeated 89 times ...
ArcGIS Portal Feature Service Writer: Writing features for layer/table 'gid_stormwater_1', with 0 inserts, 1000 updates, and 0 deletes
... Last line repeated 94 times ...
ArcGIS Portal Feature Service Writer: 'updateResults' error for a feature in 'gid_stormwater_1'. The error code from the server was '10510' and the message was: 'Operation rolled back.'
... Last line repeated 568 times ...
ArcGIS Portal Feature Service Writer: 'updateResults' error for a feature in 'gid_stormwater_1'. The error code from the server was '10583' and the message was: 'A value passed for the field 'public_description' is invalid.'
ArcGIS Portal Feature Service Writer: 1000 features successfully written to 'gid_stormwater_1', but the server rejected the 1000 features in the last request due to errors. See warnings above. Aborting translation
ARCGISPORTALFEATURES writer: A fatal error has occurred. Check the logfile above for details
If I "Remove" the public_description field using the AttributeManager, it publishes fine.
I was guessing it could be something to do with some accented characters in the public_description field, though I do see these characters successfully published to Portal when published manually.
I tried using a StringPairReplacer to swap these out, but either I'm not getting them all or it's something else.
The dataset publishes fine on its own to Portal, it just seems to be the update process where it is getting stuck. I'm new to this extension/FME world so it could be something super obvious. I appreciate any suggestions!
The entire workspace so far...
Thank you
