Running an etl tool from data interoperability server from arcgis enterprise
232
01-05-2025 07:45 PM
WahidIbneZakir
Hi everyone,
Greetings.
I have published an etl tool in arcgis data interoperability server.
But from there I can't run the etl tool.
Whenever I try to run the tool from server it says that the tool is this error shows:
  • esriJobMessageTypeError: Invalid value for parameter Source Autodesk AutoCAD DWG/DXF File(s): - Details :
Now I tried to find any documentation for the parameter insertion but could not find any.
Thanks in advance
BruceHarold
Hi, if you're using the REST endpoint, then the input parameter needs to be a URL to a file (perhaps at a UNC path), or a server/portal item id.
https://developers.arcgis.com/rest/services-reference/enterprise/gp-overview/#input
