Arcade dateDiff no work in expression date ( DASBOARD )
354
06-23-2023 06:48 PM
MarceloCatalão
New Contributor II
very good evening, I'm trying to put the following code:
var endDate = Date('12/31/2023','MM/DD/YYYY')
var startDate = Today()
var age = DateDiff(endDate, startDate,'days')
I want it to return the number of days in an indicator
but when testing the value it presents me is null
is there any way to get around this problem?
thank you very much
DanPatterson
MVP Esteemed Contributor
KenBuja
It doesn't understand which value you're wanting to return. If you add this, does it return the expected value?
return age;
