I would like to know if the direct model export from CityEngine 2016.x to LumenRT 2015 is compatible and working as it is from CityEngine 2015.1 to LumenRT 2015.
We would like to update our CityEngine version to 2016, but we don't want to lose the awesome possibility to export models directly to LumenRT 2015.
Thank you in advance and best wishes
Natan
Nope. You can manually specify the 2016 folder when installing Lumen but it won't work. 2015.0 and .1 only AFAIK.
Ok, thank you very much for your answer!
Best wishes
Please also refer these GeoNet threads:
Ok, thank you very much!
Have a nice day,
Natan
