Python API in Notebooks fails to honor filtered feature layer
290
02-04-2022 07:33 AM
Jay_Gregory
I am using Jupyter with most recent version of the Python API.  In my 10.9 Portal, I have created a feature layer item and set a filter and simple renderer (using the visualization tab) for the point feature service the feature layer points to.
When I use Jupyter to retrieve that feature layer item (by itemid) and add it to a new map in my notebook, the layer that draws is the underlying feature service (all records and the symbology that was set on publication of the map service).  It doesn't honor the filter or the symbology I set in Portal.
Is this expected?  If so, is there any plans to support honoring the Portal item properties in that regard?
