I am just getting started with SeDF and I was wondering on how I can actually visualize objects with multiple geometries.
Following the introduction, a buffer geometry is added to the dataframe. The map widget of my notebook is however, only showing the points. How can I visualize the buffer geometries?
Is there a way to specify what geometry column should be used for the visualization?
# generates map widget visulizing the points, though info widgets places two objects there, when I click on a point
point_df.spatial.plot()
# AttributeError: 'Series' object has no attribute 'spatial'
point_df.Buffer_2.spatial.plot()
# Since plot generates a MapView, the object is not subscriptable
point_df.spatial.plot()['Buffer_2']
# or has no attribute 'Buffer_2'
point_df.spatial.plot().Buffer_2
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
