Generating a list of all publicly shared feature services with the editing capabilities turned on in our Portal
1334
09-28-2021 03:30 PM
JennieCatalano1
New Contributor III
I'm looking for a way to find all the Feature Layers in our Portal that are shared publicly (with everyone) and have editing capabilities enabled.  I'm using Jupyter notebook and Portal 10.8.1.
MehdiPira1
@JennieCatalano1 ,
The following code snippet extracts a list of publicly shared items which are also editable:
items = gis.content.search("*", item_type='Feature Service', max_items=1000, outside_org=True,)
for item in items:
    try:
        layers = item.layers
        if 'Editing' in layers[0].properties.capabilities:
            print(f"Editable Layer: {item.title}, Capabilities: {layers[0].properties.capabilities}, Share Type: {item.shared_with}")
            continue
    except:
        pass
 This is set to 1000 items and you can also change it.
I hope that's helpful.
IhabHassan
Hi @JennieCatalano1
The code sample here is a good guide for how to search for "FeatureService" from a Jupyter notebook:
https://developers.arcgis.com/python/guide/accessing-and-creating-content/
Also, from the API for Python doco, adding here link to the "Item" class property "shared_with" which can indicate how the Feature Service item is shared: https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html?highlight=item#arcgis.gis.Ite...
So, the typical workflow would be to query Portal content and get all feature services, then loop over the list and find which is shared publicly.
Regards
Ihab
MehdiPira1
@JennieCatalano1 ,
for item in items:
    try:
            continue
    except:
        pass
