Bug with append using ArcGIS API for Python
295
04-08-2024 02:42 AM
GeeteshSingh07
Occasional Contributor II
Hi everyone,
Has anyone experience a bug with append module in Portal for ArcGIS?
Append shapefile to feature layer -> doesn't work
Append featureCollection to feature layer -> doesn't work
Append CSV  to feature layer -> works
However, in ArcGIS Online everything works fine.
Please let me know if anyone this is a bug or if there is any workaround.
DanPatterson
MVP Esteemed Contributor
perhaps
BUG-000141373 for ArcGIS GIS Server (esri.com)
BUG-000131932 for Portal for ArcGIS (esri.com)
but there are others related to
... sort of retired...
GeeteshSingh07
Thank you @DanPatterson. I'm facing issue with 'Append feature' function in API for python. I believe these bugs are for arcpy 'Append tool'....
DanPatterson
You might be better off going to the github site and examining the issues section
Issue search results (github.com)
since "append" will use either arcpy or shapely methods depending on installation
JakeSkinner
Esri Esteemed Contributor
Hi @GeeteshSingh07,
Can you post some of the code that is not working for you?
GeeteshSingh07
@JakeSkinner thank you for looking into it. Yes, the code is:
poly_layer = gis.content.get("e7e052cc4ad044798c4f5a6c893f20a3")
target_FL = poly_layer.layers[0]
status= target_FL.append(item_id="0472cbe2496c48e580f56d5c04155182",                        upload_format='shapefile',
                        field_mappings=[{"name":"OBJECTID", "source":"FID"}],
                        append_fields=["OBJECTID"])
status
Here, target_FL is feature layer on ArcGIS Portal & "0472cbe2496c48e580f56d5c04155182" is itemID of a shapefile.
Also, if we use featureCollection instead of shapefile, it doesn't work either.
Reference: https://developers.arcgis.com/python/guide/appending-features/
