Connect to geodatabase using .SDE file
4926
04-25-2014 08:53 AM
JamariPowers
Working in C#
I have been working with arcObjects and researching connecting to a geodatabase. I already have a working .SDE file created. Again, my lack of understanding and the convolution from the ArcGIS resource center is causing me confusion. I am not sure where to start exactly. I have bits and pieces as far as understanding.
I believe I must start with an IFeatureWorkspace. From this I am supposed to use sdeWorkspaceFactoryClass, correct? I was going to use a line of code as follows:
IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactoryClass();
m_ReadOnlyWorkspace = (IFeatureWorkspace)workspaceFactory.OpenFromFile(nameOfFile, 0);
where "m_ReadOnlyWorkspace" is my created workspace and "nameOfFile" is my sde file. Should my "nameOfFile" variable be the entire path to the .SDE file or just the name of the file?
Once I am able to make this line work, I should be [connected] to the database and able to run a query from a table correct? Am I missing any intermediate steps in the process?
Any help or insight on these issues / questions would be greatly appreciated. Thanks in advance.
AhmedEl-Sisi
it should be the entire path of the file
// For example, connectionFile = @"C:\myData\Connection to Kona.sde".
public static IWorkspace ArcSdeWorkspaceFromFile(String connectionFile)
    Type factoryType = Type.GetTypeFromProgID(
        "esriDataSourcesGDB.SdeWorkspaceFactory");
    IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance
        (factoryType);
    return workspaceFactory.OpenFromFile(connectionFile, 0);
once you get your IFeatureWorkspace, you can get your featureclass/table
for more info:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000003s8000000
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/IFeatureWorkspace_Interf...
JamariPowers
Thanks for your response. I think I may have got it. I created a function myself. The script is below:
public static class Utilities
         public static IFeatureWorkspace m_FeatureWorkspace =null;
         private static IFeatureWorkspace m_ReadOnlyWorkspace = null;
         private static string _path = "C:\\Users\\Me\\MyStuff\\MyProject\\myFile.sde";
        public static IFeatureWorkspace connect()
            IWorkspaceFactory _workspaceFactory = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactoryClass();
            m_ReadOnlyWorkspace = (IFeatureWorkspace)_workspaceFactory.OpenFromFile(_path, 1);
            return m_ReadOnlyWorkspace;
I believe this to be correct and working. What do you think?
I guess I would need to be sure, so I am also working on a conditional statement to "do something" or output a message whether I am actually connected to the sde file or not.
AhmedEl-Sisi
Your code should work fine.
If you method returns an object you should be connected.
