"Error The geometry cannot fall outside the replica extent"
4940
04-03-2014 05:38 AM
RebeccaGeauvreau
Hi there,
I've been successfully using Collector to collect data (disconnected) for a couple of weeks now.  Yesterday a new error popped up when I tried to submit a point.  I get the same error for all features in the map.  It says 'Error The geometry cannot fall outside the replica extent'.  I've tried a few different things; resaving and syncing map with wider extent but with no luck.  Any thoughts?
Rebecca
UPDATE: The problem can be solved by going to 'Item Details' of map; 'Edit'; 'Properties' and then choose Set Extent.  This allows you to change the extent of the map; resave and reload to mobile device.
