How to delete feature dataset and feature class SDE  ?
6433
02-25-2014 04:57 AM
TaiBui
Hi everyone,
Are there anyone know the statements/methods to delete a SDE feature dataset and a SDE feature class from SDE database ? (using C# or VB)
Thank you very much.
Tai
NeilClemmons
Honored Contributor
Use IDataset.Delete.  I would imagine you can't delete feature datasets unless they are empty though.
TaiBui
Thanks Neil,
I got the error: Layer in use SDE when trying to delete.
Please see my code:
                        IDataset pdataset;
                        pdataset = (ESRI.ArcGIS.Geodatabase.IDataset)featureClass;
                        if (pdataset.CanDelete() && pdataset != null)
                            pdataset.Delete();            // Throw exception
Do you know how to fix this ?
Thanks and regards,
Tai
NeilClemmons
Honored Contributor
Where is the feature class in use?  If it's in your map document then you probably need to disconnect the layer from its data source (IDataLayer2.Disconnect) and delete it from the map.
RobertBorchert
Honored Contributor
Compress your database, you should unregister as versioned those what you wish to delete.  compress it again.
shut down all programs accessing the SDE, compress it and try it again.  if that does not work go into SQL Server Configuration Manager and restart the service.  That will issue a kill command to anything connected.
