Example Helloworld does not work
1826
02-22-2014 04:25 PM
JehoshuaJosue
I downloaded the sample "helloworld" and I already have everything installed, but it "stops unexpectedly" on my android device. I looked at the debugger, and it has this "source not found" message.
Here's my log cat
02-22 18:13:18.905: I/dalvikvm(29725): Debugger is active
02-22 18:13:19.105: I/System.out(29725): Debugger has connected
02-22 18:13:19.105: I/System.out(29725): waiting for debugger to settle...
02-22 18:13:21.117: I/System.out(29725): debugger has settled (1476)
02-22 18:13:21.487: D/dalvikvm(29725): GC_EXTERNAL_ALLOC freed 46K, 43% free 3089K/5379K, external 0K/0K, paused 39ms
02-22 18:13:21.547: W/dalvikvm(29725): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonParser;)
02-22 18:13:21.557: W/dalvikvm(29725): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonParser;)
02-22 18:13:21.557: W/dalvikvm(29725): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonNode;)
02-22 18:13:21.557: I/dalvikvm(29725): Could not find method org.codehaus.jackson.JsonNode.get, referenced from method com.esri.core.symbol.SymbolHelper.createSymbol
02-22 18:13:21.557: W/dalvikvm(29725): VFY: unable to resolve virtual method 18553: Lorg/codehaus/jackson/JsonNode;.get (Ljava/lang/String;)Lorg/codehaus/jackson/JsonNode;
02-22 18:13:21.557: D/dalvikvm(29725): VFY: replacing opcode 0x6e at 0x001b
02-22 18:13:21.557: D/dalvikvm(29725): VFY: dead code 0x001e-0088 in Lcom/esri/core/symbol/SymbolHelper;.createSymbol (Lorg/codehaus/jackson/JsonParser;)Lcom/esri/core/symbol/Symbol;
02-22 18:13:21.567: W/dalvikvm(29725): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonParser;)
02-22 18:13:21.567: W/dalvikvm(29725): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonNode;)
02-22 18:13:21.567: I/dalvikvm(29725): Could not find method org.codehaus.jackson.JsonNode.get, referenced from method com.esri.android.io.a.a
02-22 18:13:21.567: W/dalvikvm(29725): VFY: unable to resolve virtual method 18553: Lorg/codehaus/jackson/JsonNode;.get (Ljava/lang/String;)Lorg/codehaus/jackson/JsonNode;
02-22 18:13:21.567: D/dalvikvm(29725): VFY: replacing opcode 0x6e at 0x0005
02-22 18:13:21.567: I/dalvikvm(29725): Could not find method org.codehaus.jackson.JsonNode.getTextValue, referenced from method com.esri.android.io.a.a
02-22 18:13:21.567: W/dalvikvm(29725): VFY: unable to resolve virtual method 18556: Lorg/codehaus/jackson/JsonNode;.getTextValue ()Ljava/lang/String;
02-22 18:13:21.567: D/dalvikvm(29725): VFY: replacing opcode 0x6e at 0x000b
02-22 18:13:21.567: D/dalvikvm(29725): VFY: dead code 0x0008-0008 in Lcom/esri/android/io/a;.a (Lorg/codehaus/jackson/JsonNode;)Lcom/esri/core/symbol/Symbol;
02-22 18:13:21.567: D/dalvikvm(29725): VFY: dead code 0x000e-001b in Lcom/esri/android/io/a;.a (Lorg/codehaus/jackson/JsonNode;)Lcom/esri/core/symbol/Symbol;
02-22 18:13:21.567: D/dalvikvm(29725): VFY: dead code 0x001f-0074 in Lcom/esri/android/io/a;.a (Lorg/codehaus/jackson/JsonNode;)Lcom/esri/core/symbol/Symbol;
02-22 18:13:21.588: W/dalvikvm(29725): Exception Ljava/lang/UnsatisfiedLinkError; thrown while initializing Lcom/esri/android/map/MapSurface;
02-22 18:13:27.874: I/dalvikvm(29725): threadid=4: reacting to signal 3
02-22 18:13:27.874: D/dalvikvm(29725): threadid=1: still suspended after undo (sc=1 dc=1)
02-22 18:13:27.874: E/dalvikvm(29725): Unable to open stack trace file '/data/anr/traces.txt': Permission denied
Please shed some light on the matter. Thanks
AlexanderPataridze
Have you converted helloWorld project to ArcGis project?
JehoshuaJosue
Convert it to arcgis project? I'm not sure what you mean..
DanO_Neill
In Eclipse, Right Click the Project and select ArcGIS Tools > Convert to ArcGIS Android Project.  Refer here for more information about ArcGIS Feature tools in the Eclipse plugin.
