spatial resolution
1752
11-19-2013 01:45 AM
OliviaGill
How can I determine the spatial resolution of a map - is this derived from the scale of the mxd, as this is not set so is there a way of doing this?
Any help appreciated.
michaelcollins1
Old school was .5 mm on a printed map was the smallest practical feature you could draw. That gives you 25 m resolution on a 1:50,000 map
I think that your question needs more context though.
ParitoshGupta
The resolution is not dependent upon the scale of the map. Resolution is defined as the minimum distance between two objects on a map, so that the objects can be distinguished for view. It refers to the pixel size of the map in question.
