This release of Geodatbase is either invalid or out of date.
2741
04-29-2013 01:29 AM
EmadAl-Mousa
I am trying to migrate an ArcSDE Geodatabase from one database server to another. i am doing that using Oracle Dumps for the Geodatabase schemas (SDE,...etc).
The Source Geodatabase:
ArcSDE 10.0 Service Pack 5
Oracle 11gR2 (11.2.0.3.5)
Server: IBM AIX 6.1
after successfully importing the dumps to the destination database server, when i try to connect to the Geodatabase either using ArcCatalog 10.0 or 10.1 i receive the following error message:
DBMS table not found [ORA-00942: table or view does not exist]
[SDE.GDB_Release]
please note that i am not installing (ArcSDE binaries) on the destination database server, my intention is to have a 2-tier architecture.
Any Suggestions ?
Regards,
VinceAngelo
Esri Esteemed Contributor
It appears you missed some SDE tables in your transfer procedure.
Even if you have no intention to run an application server, best practice
is to install (and pacth) the ArcSDE binaries.
- V
