Turn off automatic stretch when opening raster?
2701
5
04-26-2013 12:43 AM
GeospatialTechnology
Whenever I open an aerial image in arcgis a stretch is automatically applied in the raster symbology.
How do I stop this from happening?
In the raster layer properties symbology tab I want the stretch type to always display as 'None' and for no 'Gamma Statistics to be applied'
EricRice
Esri Alum
Hi Mark,
Go to Customize > ArcMap Options > Raster tab > Raster Layer sub tab and set the default to None.  Also see this two part blog on this exact topic.
http://blogs.esri.com/esri/arcgis/2012/09/19/stop-stretching-my-imagery-please-part-1/
http://blogs.esri.com/esri/arcgis/2012/09/26/stop-stretching-my-imagery-please-part-2/
You can also check out the help topic, "Setting default raster display options" which documents this as well.
Best,
Eric
ModyBuchbinder
Hi Eric
Is there any way to controlling it by setting a Mosaic Dataset properties?
If the manager thinks that the default stretch is not so good s/he cannot go into each user machine and change it.
More than that �?? some other rasters might be better with the default stretch but not all of them.
Mody
Thanks for the help erictrice
EricRice
Esri Alum
Hi Eric
Mody
Did you read part 2 of the blog I linked to?  Check that out and let me know if you still have questions.
Best,
Eric
ModyBuchbinder
Hi Eric
Thanks, that what I was looking for. My understanding was that this is client setting - I was wrog.
Mody
