Printing/Exporting an Index Grid created in the Data Frame Properties
3500
02-19-2013 04:27 PM
IanSullivan1
GOAL: Print and/or Export map created in Map Layout view with the Index Grid created in the Data Frame Properties window.
STATUS: In map layout view, I have an 8x8 index grid along the entire border of my map. When I export the map as a PDF, the index grid TABS [along the top/bottom & side of map] do not export into the document. The index grid LINES do export into the PDF however.
REQUEST: Please direct me to any tools, resources, or export functions that will solve my 'missing index grid tabs' problem.
IanSullivan1
Problem Solved: It appears that I accidentally extended/stretched/expanded the index grid beyond the boundary of the map layout.  I simply re-sized/reduced/shrank the index grid back down to witing the map boundary.  I now have the index grid tabs included in my exported map.
Thanks.
ArcGIS 10.0 (student version), Arc Info
I have attached the PDF version of the map. As you can see, the grid lines were included.
I created an 8x8 grid, like so:
___1 2 3 ...
A|
B|
C...
I will post a screenshot of my map layout and my grid components later today once I return to my computer. My ultimate goal is to include the index grid tabs around the border of my map so that when users refer to the data in parenthesis [within the legend] they can navigate to that feature quickly.
IanSullivan1
Thanks.
___1 2 3 ...
A|
B|
C...
