combobox - vb.net - set default value to show in dropdown when loaded
38583
12
01-03-2013 04:53 AM
maxsteinbrenner
so i have a add-in combobox and would like it to have the text "select storm" in the (currently blank) dropdown when the combo box is displayed. is this possible?
thanks!
max
KenBuja
MVP Esteemed Contributor
Not a dumb question at all, especially since I gave you an incorrect answer the first time.
In the Config.esriaddinx file, if you add a space to the Combobox line, you should get Intellisense to pop up, showing the possible tags you can add. Use hintText. The sample Custom Selection Extension shows this and other tags that you can use.
KenBuja
You can set the combobox's text property to "Select storm". Once something is selected, that text will not show up again.
maxsteinbrenner
probably a dumb question but:
where would/how i access the text property of the combobox? i would know how to do it if i made the combobox in the designer but this one is an add-in and i am unfamiliar with how to access it's properties.
thanks,
max
KenBuja
maxsteinbrenner
Kevin,
awesome!
that is exactly what i was looking for, thanks so much.
max
KenBuja
Glad to help. Please remember to click the check on the post to signify the question was answered.
NeedHelp
What is the best way to either:
a.) have the default text re-appear after a combo item has been selected OR
b.) have the combo box value default to the first item in it's list??
KenBuja
You can set the combobox to the first item in the list this way
myComboBox.SelectedIndex = 0
NeedHelp
I don't see the .SelectedIndex as an option like I do with a 'normal combo box'.
All the interaction I have with the combo box add-in is done via the "me." command.
I can do me.add or me.remove to adjust combo box items, but definitely don't have the full list of options I'm used to working with combo boxes.
lethalmark
see more about...   vb.net combobox databinding
marc
