Popup 3.0 - hide field if value=null
10283
10
09-27-2012 09:21 AM
philippschnetzer
using the latest flaxviewer 3.0.  I would like my popups to hide fields if they do not contain a value. Can this be done easily? I'm assuming it will need to happen in the mxml and not the xml, correct? Thanks
DasaPaddock
Yes, you need to create a custom PopUpRendererSkin. Try making this change to line 163 of PopUpRendererSkin.mxml:
    if (fieldInfo.visible && formattedAttributes[fieldInfo.fieldName])
PopUpRendererSkin.mxml is in the skins folder inside the API's zip file.
DasaPaddock
GeorgeHaskett
Is it possible to do this if you are using the Flex Viewer 3.0 in compiled mode using xml?
I'm new to Flex and am currently customizing widgets in I believe the compiled mode.
How difficult would it be to figure out the option you mentioned previously and what software is best to use when editing the code?
DasaPaddock
You'll need to recompile the Viewer to make any changes to mxml source files.
See:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Flex_development/01m30000002000...
GeorgeHaskett
Haskett
RhettZufelt
MVP Notable Contributor
Hi Dasa,
was wondering if there is anything else one needs to do to make this happen?
I have made the change to my PopUpRenderSkin.mxml, but I still get fields in my popup that have null values:
[ATTACH=CONFIG]18124[/ATTACH]
R_
DasaPaddock
Rhett,
It looks like all the fields in your screenshot have values.
RhettZufelt
Whoops, clicked on the wrong well.
[ATTACH=CONFIG]18125[/ATTACH]
However, after re-boot, re-clear everything, it seems to be working now.
[ATTACH=CONFIG]18126[/ATTACH]
Thanks for the help,
R_
RhettZufelt
Hi Dasa,
In several of my data sets, I often end up with a space in the "empty" cells.  Is there a way to modify this so that a single space is also filtered out as well as blanks and Nulls?
Thanks again,
R_
DasaPaddock
Try:
if (fieldInfo.visible && formattedAttributes[fieldInfo.fieldName] && formattedAttributes[fieldInfo.fieldName] != " ")
