file gbd(*.gdb) schema info
1358
09-19-2012 06:37 PM
zszs
i need use file gdb(*.gdb) with out arcgis,who can tell me file gdb(*.gdb)  schema infos
thanks a lot
zszs
please help me,i need file gbd(*.gdb) schema info,please show me some links about this
LanceShipman
There is no way to use a File Geodatabase outside of ArcGIS except through the File Geodatabase API. See http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-api. The API only works with version 10.0 and above data.
zszs
thank you very much
