How to adding dynamic text from an attribute field to Data Driven Pages
1692
7
09-18-2012 09:42 AM
KenLucas
How do I add the data, from a specified attribute field in my DDP index layer, as dynamic text onto my DDP page? I've studied the insert - dynamic pick list with DDP pages enabled.
Ken
JonathanQuinn
Esri Notable Contributor
You should be able to change the property value to whatever field you want to display as dynamic text:
<dyn type="page" property="<field_name>"/>
KenLucas
Jonathan,
  I didn't think of making a change to the tag code. I'll try it and reference an attribute field. Thank you,
Ken
CPoynter
Is it possible to get an attribute value and place it into dynamic text? I have a python script that iterates over an attribute field, and I would like to record the field value as dynamic text as my layout changes.
Regards,
Craig
JonathanQuinn
Craig,
I assume that the value you'd like as dynamic text is not in your index layer?
CPoynter
Hi Jonathon,
I have a layout with three sets of data with a common field. I have a script that will use the common field and create a definition query to display only the relevant value being iterated over. I was hoping for a method of adding the value being presented as dynamic text or through some other python (arcpy.mapping) process. Not using DDPs for this workflow.
Regards,
Craig
JonathanQuinn
You could do the same thing using Data Driven Pages, page definition queries, and dynamic text, if you're fine with not using a script.  You can set page definitions on any layer that contains the index field for the data driven pages.  Alternatively, I don't know of any way through Python to have dynamic text.
CPoynter
Hi Jonathon,
I will investigate Page Definition Queries. They might work, but I need three FCs to react the same (set to same definition) and have about a dozen values in the relevant attribute field to try with.
Thank you for advice.
Regards,
Craig
