Basic GIS query!
1318
08-10-2012 07:22 AM
EamonnDolan
Hi
I'm sure there is a very simple solution to this so here goes...
I have three layers in ArcMap 10
1. U.K Coastline
2. Onshore oil well points
3. UK Roads
All I wish to achieve is to determine the overall average distance between the wells and roads.
How do I achieve this?
Eamonn
by Anonymous User
Not applicable
You can use the "Generate Near Table" function using the well points as the input and your roads as the near features.  The output table will give you the distance from all the well points to the nearest road.  From the table, you can simply summarize the distance field using the mean statistic. See the help for this tool below:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000001n000000
Caleb
EamonnDolan
Caleb
Yep!  That's worked Caleb.
Much appreciated!
