Load AIS Data Model
2911
05-23-2012 12:57 PM
30013001
How do you load the AIS data model into the product library so it is an option in the Production Properties?
Thanks!
AeronauticalSolutionTeam
Setting the Data Model Version is available within the Production Properties -> Tool Options -> Data Models.
Within the Data Models dialog you can Add or Create any data model you wish to be recognized within your production system.
Please follow the steps from the Creating A New Data Model Version help document to define and add the AIS data model provided with the Esri Aereonautical Solution.  The AIS and AIS_Charting xml schemas can be found on your local machine at C:\Program Files (x86)\ESRIAeronautical\Desktop10.0\Schemas.
In the New Data Model Version box, should the Data Model Workspace be set to the production database or to the AIS schema?
Thanks!
The Data Model Workspace should point to the AIS schema. The location of this xml workspace is noted in the previous post.
The on-line help contains the instructions for creating a new data model version.
