create O-Blocks
2424
04-17-2012 08:24 PM
JesseGould
I am trying to create O-block shaped lots.  Basically I am drawing shapes in city engine however i need basically a donut shape.  Is there a way to boolean out a shape within a shape.?
thanks
jesse
MatthiasBuehler1
1] if subdividing a Block with the Dynamic City Layouts : use the Block Subdivision Type 'Offset Subdivision'
2] if you try doing this via CGA : check the CGA operation called shapeO() in Help > CGA Operations Reference
3] note that CGA does not yet support polygons with holes, thus shapeO creates a 'diagonal line' to split the otherwise closed topology of the shape open.
