max function
2927
03-06-2012 06:39 AM
RameshGautam
Does Python has 'max' function?
I need to find maximum value among hundreds of variables. For example, I have 2, 3, 4, 1, 2, 3, 4, 5, 1, 2, 3, 0, 10, 20, etc and I would like to write a code like
max(2, 3, 4, 1, 2, 3, 4, 5, 1, 2, 3, 0, 10, 20) and get the maximu value. I tried, somehow it did not work.
I found a max function in ArcGIS help as
max([!field1!, !field2!, !field3!])
what does ! mean?
curtvprice
Yes, it should work. there are two valid syntaxes:
>>> max(3,2,1,5)
5
>>> max([3,2,1,5])
5
what does ! mean?
This is the python max function (second syntax), used inside the Calculate Field tool (which uses a "!" delimeter to substitute field names in to Python expressions).
