Grid Reference in Layout View
1875
08-26-2011 07:18 AM
DanEvans
Is there a way to insert the grid reference/X Y co-ordinates of the centre of the data frame in layout view? I'm working in British National Grid projection...
Cheers
Dan
DavidWatkins
Esri Alum
Hi Dan,
You could write a Python script that would return the extent of the data frame, do the math to find the center, and then update a text element in the page layout with the coordinates.
Start with the help topic on the DataFrame properties available through Python found here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/DataFrame/00s300000003000000/
Then you can find an example of updating a text element with Python here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/TextElement/00s30000000m000000/
If you are new to Python, a good place to start is with the following Blog Post:
http://blogs.esri.com/dev/blogs/arcgisdesktop/archive/2010/09/24/getting-started-with-python-map-aut...
Hope this helps,
David
DanEvans
Thanks David, I'll give it a try.
Dan
DanEvans
I forgot to mention I'm using 9.3 - is it still possible?
DavidWatkins
Esri Alum
Hi Dan,
The Python methods I was describing are only available at 10 or later. You would need to write something using ArcObjects at 9.3.
David
