Updating table URLs in web map with AGO assistant
1041
09-28-2020 02:25 PM
SaraJK
I have a file geodatabase that is being hosted as feature layer on AGOL. It has both layers and tables. I have several web maps set up with both layers and tables in them which are being used for several dashboards. I need to update the schema of my database (so uploaded a new one) and assumed I could use AGOL assistant to update the URLs in the web map. The update to the layer URL seems to be working, however the tables still point to the old layer. I tried to find/replace the path and also tried to update the JSON directly. Is this a limitation with the Assistant? Do I have to recreate all the web maps?
