Getting error when trying to add a feature to a dataset: Object name is not a regular identifier for the underlying DBMS
2975
09-09-2020 09:20 AM
GarethPalmer
As described in the title, whenever we try to add a feature to a dataset in our SDE database or the service that uses it, the features fail to draw and we get the error message "Object name is not a regular identifier for the underlying DBMS".
Any help would be appreciated.
Tags (3)
JeremiahGlascock
Not sure if you figured this out yet but we had the same error and it turned out to be a field name length issue. Shorten your field name and see if that helps.
