SQL dump to Excel
3262
6
07-13-2020 03:33 PM
CCWeedcontrol
I am trying to do a SQL dump of a table to excel but I can't get past the error, what am I doing wrong?
Error line 14
'utf8' codec can't decode byte 0xc3 in position 0: invalid continuation byte
import pyodbc
import pandas as pd
import os
cnxn = pyodbc.connect("Driver={SQL Server};"
                      "Server=***;"
                      "Database=***;"
                      "uid=***;pwd=***")
cursor = cnxn.cursor()
script = """
SELECT * FROM ***.***
df = pd.read_sql(script, cnxn)
writer = pd.ExcelWriter(r'C:\Temp\export.xlsx')
df.to_excel(writer, sheet_name ='Sheet1', encoding='utf-8')
writer.save()
JoeBorgione
I just dealt with that same problem see: Unicode Errors   Line14, change
encoding='utf-8'
#to
encoding='utf-16'
CCWeedcontrol
utf-16 didn't work, adding reload(sys) , sys.setdefaultencoding('Cp1252') to my code worked.
Thanks tho.
import pyodbc, sys
import pandas as pd
import os
reload(sys)
sys.setdefaultencoding('Cp1252')‍‍‍‍‍
JoeBorgione
Ah, yes I've used that too.  Glad you got it going none the less; those errors are a pain.
JoshuaBixby
MVP Esteemed Contributor
The SQL Server default collation for many Windows locales is Latin1_General_CI_AS .  For English(United States), the default collation SQL_Latin1_General_CP1_CI_AS. Both of those collations use code page 1252 (CP-1252).
Collation and Unicode support - SQL Server | Microsoft Docs
CCWeedcontrol
The first time I was using 2.y python, which worked yesterday but today nothing happens when I run the script, no error no output .xlsx.and I didn't change anything, I am lost on this one. So i decided to try it on 3.6 so in 3.6 I have to add from importlib import reload  and comment out sys.setdefaultencoding('Cp1252') but in doing so I get the same error, on line 17 'utf8' codec can't decode byte 0xc3 in position 0: invalid continuation byte. Thoughts?
mport pyodbc
import pandas as pd
import os
reload(sys)
#sys.setdefaultencoding('Cp1252')
                      "Server=***;"
                      "Database=***;"
                      "uid=***;pwd=***")
script = """
writer.save()
JoeBorgione
Throw in a few print() statements along the way or use a try/accept block and see it tosses something for you.
