Why doesnt ArcGIS Pro recognize an installed module?
1337
07-06-2020 08:06 AM
NikolaiMetaschk
Hello all,
For my Bachelor thesis I have to work with the ArcGIS API for Python. So created a new Python-environment, which actually is a clone of the default one, and added the required packages to use deep learning for ArcGIS. Here you can find a list of the installed packages. Then I exported training data for deep learning using the 'Export Training Data for Deep Learning' tool.
But when I try to import these data into the 'Train Deep Learning Model' tool, I get the following Error:
ERROR 032659 updateParameters Syntax Error: Traceback (most recent call last):
File "f:\programme\arcgis\arcgispro\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx#TrainDeepLearningModel_ia.UpdateParameters.py", line 4, in <module>
ModuleNotFoundError: No module named 'fastprogress'
I can´t really understand this because I already installed the fastprogress module within the fastai package. When I use 'conda list' in the Python command prompt I see that it is installed. Even in the ArcGIS Pro Settings I can find the module under the installed packages inside my environment.
Thanks.
