Spyder 4.1.3 Short Cut
3042
06-22-2020 03:30 PM
JoeBorgione
 I just installed Miniconda locally so I can do straight python programming with no interference from the ArcGIS Pro installer etc.
I installed it here:
C:\Clones\Miniconda3
and then ran:
conda install -c anaconda spyder
and created a short cut in the usual fashion:
Target:  C:\Clones\Miniconda3\pythonw.exe "C:\Clones\Miniconda3\Scripts\spyder-script.py"
Start in: C:\Clones\Miniconda3
But the short cut fails to open spyder.  Nothing happens at all. I can run the new version of spyder by going to start and entering spyder there; works fine.  Not sure why my shortcut fails...
Dan Patterson
Tags (3)
DanPatterson
MVP Esteemed Contributor
Joe Borgione
from
Installation — Anaconda documentation
If you have Miniconda or an older version of Anaconda installed, you can install Navigator from an Anaconda Prompt by running the command conda install anaconda-navigator.
To start Navigator, see Getting Started.
... sort of retired...
DanPatterson
Joe Borgione
I would use Anaconda Navigator if it was in the distribution.
Anaconda Navigator — Anaconda documentation
or from the prompt.
I only used the shortcut for Pro work.
I prefer separate machines for different messing-around-with-stuff
Good luck
JoeBorgione
Ha..  You saw this just before I went to delete it.  I cheated, and at the start command I typed in spyder, and instead of running it, I selected 'open file location' and then copied the short cut from the install directory.
target: C:\Clones\Miniconda3\pythonw.exe C:\Clones\Miniconda3\cwp.py C:\Clones\Miniconda3 C:\Clones\Miniconda3\pythonw.exe C:\Clones\Miniconda3\Scripts\spyder-script.py
start in:"C:\Users\Public\Documents\Python Scripts"‍‍‍
A little different than what I'm used to seeing...  ( Navigator must not install with Miniconda, I can't seem to find it...)
DanPatterson
Joe Borgione
from
JoeBorgione
again, you beat me to it; just installed it....
