for loop for PointCollection
1582
05-23-2020 05:04 PM
Erick_CamiloMorris_Duarte
I want to make a point collection from an Xyz file, in order to do that, I need to aggregate the points to the point collection, but it doesn't seem to work.
Esri.ArcGISRuntime.Geometry.PointCollection VMM40Points = new Esri.ArcGISRuntime.Geometry.PointCollection(Spatialreference);
for (int i = 1; i == xyz.Count / 3; i += 3)
VMM40Points.Add(xyz[i - 1], xyz, xyz[i + 1]);
JoeHershman
So you created an array the goes x,y,z,x,y,z,...  What is the original file look like, this seems an odd way to load the data from the file
-Joe
dotMorten_esri
Esri Notable Contributor
What is it that doesn't seem to work? Are you getting a crash, no points added, invalid results or?
Also if you're creating new geometries, I'd recommend looking at the GeometryBuilders, like PolygonBuilder and PolylineBuilder.
