How to use a method declared in a webApp builder widget's main js?
1441
05-14-2020 02:11 AM
DávidGregor
I have programing theory question. I need to develop the editor widget, to fill out input boxes automatically with webmapID, date, ect. I'm trying to follow the widget's techniques, but i'm unsuccesfull.
So here i want to get the webmapid in widget.js, but probably it's already not good, because i don't have 'map' in that scope. In the widget.js's startup function i call this method "this.getWebMapId(); And it returns the value.
My big problem,(except that i'm really new in programming) is how to call this method in the RelatedRecordsEditor.js's "_init" function.  Should i declare it like the Clazz object's property? What should i do with the _editWidget object in RelatedRecordsEditor?
What i have done:
widget.js:
       * Public methods
      getWebMapId: function() {
        var webMapID = this.map.itemInfo.item.id;
        console.log("webmapid: "webMapID);
        return webMapID;
RelatedRecordsEditor.js:
      dojo.connect(dijit.byId('dijit_form_ValidationTextBox_1'), 'onChange'function (webMapID) {
        var mapid=dijit.byId("dijit_form_ValidationTextBox_1").attr("value");
        console.log(mapid);
        var webMapID;
        webMapID = this._editWidget.getWebMapId();
        var update = mapid.replace(mapidwebMapID);
        console.log(update);
        dojo.byId('dijit_form_ValidationTextBox_1').value = update;
(_editWidget is undefined here.)
RobertScheitlin__GISP
Dávid,
   You need to get a reference to the edit widget in the RelatedRecordsEditor.js file. The normal way to do this is to use the WidgetManager.js class to get the widget reference.
require(["jimu/WidgetManager"], function(WidgetManager) {
  var _editWidget = WidgetManager.getInstance().getWidgetsByName('Edit');
  var webMapID = _editWidget[0].getWebMapId();
Dávid,
DávidGregor
I was trying to understand the file's communication rather. And some minutes ago a solved it like this, but i will use your answer in the future for sure.
 _init: function() {
      var webMapIDthis._editWidget.map.itemInfo.item.id;
      dojo.connect(dijit.byId('dijit_form_ValidationTextBox_3'), 'onChange'function () {
        console.log("itemid:"+webMapID)
        console.log(mapid);
        var update = mapid.replace(mapid, webMapID);
Unfortunately, i realised that it fills the inputbox, but if the user doesn't modify the string, it doesn't save the string what is inside the dijit_form_ValidationTextBox_1   so i need to figure out how to pass this value to the system.
But a thousand thanks for your help!
