Web map not loading all layers in Story Map or using field display names in map legends
569
04-29-2020 02:59 AM
GeorgeHolmes
I have made a story map with web maps added to a series of sidecars. When viewing the story, one of the maps does not display all of the web map's layers. All of the layers are visible when adjusting the web map appearance when adding the map to the story but not when viewing the story.
As well as this issue, I have edited the field display names in the underlying feature layer which holds the data for each web map and some of the maps appear to not be using the display name i have chosen in the web map legend.
My story map is here: Sign In
Map 4 is the map which is failing to load all the layers.
