Create map for each feature class in workspace
1185
03-06-2020 02:12 AM
GeorgiyYaroslavtsev
Hi!
Can somebody tell me is it possible to automate creating maps for each feature class in workspace in ArcMap with ModelBuilder or ArcPy?
JakeSkinner
Esri Esteemed Contributor
You can run the following code in ArcMap.  Just replace arcpy.env.workspace with the path to you geodatabase.
import arcpy, os
arcpy.env.workspace = r"C:\temp\python\test.gdb"
for fc in arcpy.ListFeatureClasses("*"):
    fcName = str(fc)
    mxd = arcpy.mapping.MapDocument("CURRENT")
    df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
    arcpy.MakeFeatureLayer_management(os.path.join(arcpy.env.workspace, fc), fcName)
    mxd.saveACopy(r"C:\temp\python\{0}.mxd".format(fcName))
JakeSkinner
import arcpy, os
    fcName = str(fc)
GeorgiyYaroslavtsev
Many thanks! You saved me a lot of time today! 😃
