Finding line segments with Null value
1488
03-03-2020 05:59 AM
brycehoward
I'm trying to find line segments with <null> as their FEEDERID that are connected to a line segment of a specific FEEDERID.
I have tried Intersection on Geometry Check with these as my definition query's, but not getting the results I need.
FEEDERID LIKE '02%__'
FEEDERID IS NULL
What would be the best way to go about this using Data Reviewer?
KumarGaurav
Hi Bryce,
I tried similar configuration with my sample data and Geometry on Geometry check with Touches option worked for me:
You can use same configuration in ArcGIS Pro as well.
Hope this helps.
Kumar
KumarGaurav
Hi Bryce,
Hope this helps.
Kumar
brycehoward
Thank you so much! This worked really well besides one thing. When I write them to the table to be corrected, it's writing the line segment with the FEEDERID since it's touching a line segment with a <null>. How can I get it to switch so the <null>  line segment gets written to the table?
Thank you again.
Edit: Just had to switch my definition queries around it worked great. Thank you!
