Why am I getting "Error: Cannot read property 'layerName' of undefined" when trying to add Feature Report
2632
02-28-2020 06:38 AM
RobCahalan
I have published a new survey using Survey123 Connect 3.7.62 and when I try to upload a .docx to the feature report I receive the following error: Error: Cannot read property 'layerName' of undefined
I have used the Survey123 Create Sample Template and I receive the same error on that template.
I have a feeling that a repeat is causing the issue, but even if I exclude the repeat section from the word doc I still get the error. I have tried publishing this report without the repeat section and I was able to use the create sample template and got it to work correctly.
Any help would be greatly appreciated....thanks!
Shwu-jingJeng
Hi Rob,
Could you share the xls form so that we can look into this further?
If you would like to share it privately, you could email it to [email protected]
KieranSroba
Hi Shwu-jing,
Did you find a solution to this? I am running into the same problem. I have attached the spreadsheet that is causing problems below
Shwu-jingJeng
Hi Kieran,
The form has repeats and use pulldata in calculation, to be able to repro the issue, it requires to have all associated resrouces to troubleshoot it. I will recommend you to contact Tech Support to have them setup a repro case in house and troubleshoot it.
