Changing map document layer data sources from file gdb to sqlite/spatialite using arcpy
705
02-18-2020 03:19 PM
StevenPaplanus
I need to write an arcpy script which will allow me to change the layers of a map document to point from a file geodatabase to a sqlite database with the same table names and data.
I was able to use the following to migrate from a gdb to a sql server database:
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\test\mytestmap.mxd")
mxd.replaceWorkspaces(r"C:\test\src.gdb","FILEGDB_WORKSPACE",r"C:\test\dest.sde","SDE_WORKSPACE")
mxd.SaveACopy(r"C:\test\newmap.mxd")
I tried to do the same with this code:
import arcpy
mxd.replaceWorkspaces(r"C:\test\src.gdb","FILEGDB_WORKSPACE",r"C:\test\dest.sqlite","SDE_WORKSPACE")
I have tried to use the destination workspace as SDE_WORKSPACE,FILEGDB_WORKSPACE, and  TEXT_WORKSPACE, but i only get "ValueError: MapDocObject: Unexpected error"
Is there another way to do this work or am I missing a step?  I need to do a batch of documents and will need to do it again in the future, so a script is the best way to proceed, if I can.
Steve
