Question about theme-grid
1288
02-18-2020 01:18 AM
מנהל_תקשובמנהל_מערכת
hi , i have created a new survey using the thee-grid, in many place i had to add more groups.
is there any way i can make the small arrow disappear?
does the theme-grid support RTL ?
JamesTedrick
Esri Esteemed Contributor
I'm not sure why you would need nested groups for the layout you are providing - you can place the 'w2' appearance in the first group to specify the layout and make the note 'w2' to have it spread to full width.
By support for RTL, are you referring to the layout of the questions within the row?
I need the nested groups because it is the only way i can place the whole group side by side.
the RTL support was referring to the placement of the fields on the form, first field right and then left.
I'm attaching screenshots with ESRI example:
this is how it looks when I have nested groups (pay attention that on ESRI sample there is no label on the nested group either:
and this is how it looks when I remove them.
JamesTedrick
I'll note that there is a difference - you're group label is not truly empty - it has <font></font> which visually is empty but has a value.
I am sorry but I didn’t quit understood your answer.
Can you please send me a sample that places repeats side by side the right way.
iris
