How do I serialize a custom class containing instances of ArcGIS Pro objects?
2452
01-14-2020 06:42 AM
StevenCorpus1
What I am trying to do is to take an instance of our custom class that is in a general format as shown below:
using System;
using ArcGIS.Core.Geometry;
using ArcGIS.OtherStuff
using SpatialReference = ArcGIS.Core.Geometry.SpatialReference;
               namespace myNameSpace
                              public class myClass
                                             private bool _field1;
                                             public bool Field1
                                                            get {return _field1;}
                                                            set
        _field1 = value;
                                             //So SpatialReference of new shapefile needs to come from NewLayerSpatialRef
                                             private SpatialReference _newLayerSpatialRef;
                                             public SpatialReference NewLayerSpatialRef
                                                            get { return _newLayerSpatialRef; }
                                                            set
        _newLayerSpatialRef = value;
                                             ..........//Other ArcGIS Pro classes
                                             ..........//Other non-ArcGIS Pro classes
Say I create an instance of this class name myInstance and populate it with all necessary properties.
I would then like to serialize the instance into a file in order to persist it for future use by doing some LIKE the following:
var writer = new StreamWriter(@“c:\temp\myFileForFutureUse.xml”);
                    XmlSerializer serializer = new XmlSerializer(typeof(myClass));
                    serializer.Serialize(writer, myInstance);
I don’t necessarily need to use the XmlSerializer class.
Is something like the above possible? Can I serialize an instance of a class that contains instances of ArcGIS Pro classes such as SpatialReference? If so, is there a particular serialization method suggested by Esri such as Xml Serialization or Binary Serialization? Are there any coding examples or white papers? Any guidance on this matter would be appreciated.
Thanks!
JohnJones
Per this Stack Overflow thread... c# - Implementing Custom XML Serialization/Deserialization of compound data type? - Stack Overflow
You may want to mark your SpatialReference (& other ArcGIS Pro objects) as
    [XmlIgnore]
and then add a string version along side...
    [XmlAttribute]    public string NewLayerSpatialRefValue { get => NewLayerSpatialRef.ToXML(); }
Deserializtion should be similar, taking the string and calling the appropriate builder type's FromXML static member.  Of course, if you have some non-serializable object; for example a feature, you would want to either serialize a primary key to it (OID), along with a reference to its datasource location, or a snapshot of its current attributes, depending on your needs.
Using this method, your serialized XML will have a string property with another XML fragment inside it rather than a 'nicer' looking direct XML sub-tree merge.  I would imagine there is some way of getting the latter behavior, but I'm not familiar with the .NET serialization libraries to get that effect and it would provide much benefit unless that was the format required by the client parsing the XML.
