Dynamic controls on custom widget ESRI WAB
1426
12-20-2019 03:45 AM
wadsonmakari
I am developing a custom widget using WAB. Below is a snippet on what the UI will look like
The controls if the red box are dynamic in the sense that they are controlled by the 2 radio buttons above. The controls shown are relevant when the Boundary radio button is selected. However, when the user selects the Site radio radio button I would like to remove these controls and replace them with controls that are relevant to the Site option.
Currently I have these controls in html template file in a div
<table style="width:100%;">
<tbody>
<div data-dojo-attach-point="myDynamicDiv">
<tr>
<td style="text-align:right;width:87.5px;">Type:</td>
<td colspan="2" style="width:175px">
<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryType" data-dojo-attach-event="onChange:addVSPBoundaryNames" data-dojo-type="dijit/form/Select"/>
</td>
<td style="text-align:right;width:87.5px;">Name:</td>
<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryName" data-dojo-attach-event="onChange:addVSPBuffers" data-dojo-type="dijit/form/Select"/>
</td>
<td></td>
<td></td>
</tr>
<tr>
<td style="text-align:right;width:87.5px;">Buffer:</td>
<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryBuffer" data-dojo-type="dijit/form/Select"/>
</td>
<td style="text-align:right;width:87.5px;">Buffer Type:</td>
<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryBufferType" data-dojo-type="dijit/form/Select"/>
</td>
<td colspan="2" style="text-align:center;">
<div class="jimu-btn" data-dojo-attach-point="btnViewAmendAdd" data-dojo-attach-event="onClick:addDataShare">Add</div>
</td>
</tr>
<tr>
<td colspan="8" style="padding:10px;">
<ul class="vspList"></ul>
</td>
</tr>
<tr>
<td colspan="8" style="width:100%">
<hr>
</td>
</tr>
</div>
</tbody>
</table>
When a user selects the Site radio button I would like to clear the contents of this div and replace them with the controls that are relevant for the Site option.
What is best approach to take? Anyone with a sample that does something similar?
I also need to be able to attach events on some of the controls.
I tried to dynamically build the controls using something like this
_buildBoundarySiteDiv: function(){
alert('here');
var html = '<tr>'+
'<td style="text-align:right;width:87.5px;">Type:</td>'+
'<td colspan="2" style="width:175px">'+
'<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryType" data-dojo-attach-event="onChange:addVSPBoundaryNames" data-dojo-type="dijit/form/Select"/>'+
'</td>'+
'<td style="text-align:right;width:87.5px;">Name:</td>'+
'<select style="padding-right:5px;width:100%;" data-dojo-attach-point="viewAmendBoundaryName" data-dojo-attach-event="onChange:addVSPBuffers" data-dojo-type="dijit/form/Select"/>'+
'</td>'+
'<td></td>'+
'<td></td>'+
'</tr>';
//alert(html);
var myContent = domConstruct.toDom(html);
domConstruct.place(myContent,this.BoundarySiteDiv);
//alert('here 2');
The controls did not have the styling as shown in the image above. Any pointers will be much appreciated.
KenBuja
MVP Esteemed Contributor
I've done this in one of my widgets using css. I have two radio buttons to choose the method
My setting/css/style.css file contains this class
.spatial-prioritization-setting .esriCTHidden {
  display: none; }‍‍‍‍
I have two radio buttons in my Settings.html file with an onclick event
<form name="prioritizationMethod">
  <div class="esriCTDownloadTabTextbox">
    <input data-dojo-attach-point="radPrioritizationCoins" type="radio" class="jimu-radio-btn"
      name="prioritizationRadio" value="Coins"
      data-dojo-attach-event="onclick: _onPrioritizationMethodChange" />
    <label
      data-dojo-attach-point="labelPrioritizationCoin">${nls.prioritization.prioritizationCoins}</label>
  </div>
    <input data-dojo-attach-point="radPrioritizationHigh" type="radio" class="jimu-radio-btn"
      name="prioritizationRadio" value="HML"
    <label data-dojo-attach-point="labelPrioritizationHigh">${nls.prioritization.prioritizationHigh}</label>
  </div>
</form>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And in my Settings.js, that onclick event adds or removes the class to my objects (and does some other things with the table)
_onPrioritizationMethodChange() {
  if (this.radPrioritizationCoins.checked) {
    html.removeClass(this.coinLimits, "esriCTHidden");
    html.addClass(this.HMLMethod, "esriCTHidden");
  } else {
    html.addClass(this.coinLimits, "esriCTHidden");
    this._prioritizationMethod = "Priority";
The item coinLimits that is being changed look like this
<div data-dojo-attach-point="coinLimits">
  <div class="esriCTDownloadTabInputContainer">
    <div class="esriCTDownloadTabLabel">
      ${nls.prioritization.allocatedCoins}
    </div>
    <div data-dojo-attach-point="allocatedCoins" data-dojo-type="dijit/form/NumberTextBox"
      data-dojo-props="constraints:{min:1,places:0},style:{width:'100%'},value:100"></div>
    </div>
  </div>
      ${nls.prioritization.maximumCoinsPerCell}
    </div>
      <div data-dojo-attach-point="maximumCoins" data-dojo-type="dijit/form/NumberTextBox"
      data-dojo-props="constraints:{min:1,max:100,places:0},style:{width:'100%'},value:10"></div>
    </div>
  </div>
</div>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
wadsonmakari
Thanks I will try this approach and let you know how I get on. Thank you very much.
