Attribute Rules Trigger: Exclude attribute update from trigger?
862
11-06-2019 08:04 AM
ThomasColson
So with attribute rules, I can trigger them on update, but it appears I can't constrain to what specifically is being updated. With a SQL trigger, I can constrain the update to just fire if the geometry is updated...in other words, only fire the what state is this point in trigger if the point is moved. There is a performance hit for firing the spatial trigger if all I'm doing is updating attributes...there is no need to fire the trigger.
I'm looking for the same behavior in Pro.....I don't want the attribute rule to fire on attribute updates, I only want it to fire on geometry updates. Is this possible?
