Login Screen for the Flexviewer
48033
121
03-15-2011 10:52 AM
andrewj_ca
Just posted some code for a Flexviewer login screen.  I hope somebody can get some use from this.
http://www.arcgis.com/home/item.html?id=baebcaf317994d63902bc9735c0657e0
andrewj_ca
Code has been upated to include a sample asp web service for user validiation.  Please remember to specify from URL in the index.mxml file.  It currently says 'localhost'.  Cheers
KenBuja
MVP Esteemed Contributor
This would be more useful in the ArcGIS Viewer for Flex forum
andrewj_ca
I agree to a certain extent.  The code I put up transcends the sample viewer.  This sample will work with any flex implementation.  Cheers and enjoy.
MichaelMatela
Andrew,
I got the Login Screen up and running, however I can't get the "siteUsage.log" to update as connections are made or attempted. Is this setup to run out-of-the-box or is there something more I need to do first?
IvanBaehr
Hi Andrew,
Great with a login widget. Will there be any chance that you post a compiled widget for flexviewer 2.2 in near future? We are looking forward to add the login widget to our flexviewer web map.
Ivan Baehr
Web Mapping Specialist
UNOSAT
andrewj_ca
I will definately be doing more with this.  I have a few deadlines in the next couple months and it's a bit busy around here.  I'll do a fully configurable upload.
JamesFaron
I was able to successfully implement Andrew's asp.net web service to complete the login process. But, for the sake of demonstration, I would like to create several users in the users.xml, and return a value unique for each one, by for example using the GetUser function in vb. I am not a vb programmer, and thus would appreciate any help in modifying the Service.vb to return a value from the user's profile after the user is validated. I know this is not a vb forum, just thought I might get lucky.
The Flex angle is as follows: if I can return a value from the user profile, in my case a location code, I can assign it to a global variable in the index.mxml. I will then call that variable in a widget, in this case, to input the value in a feature's definition expression, so that only the data that the user is authorized to see will appear in the layer on the map. I can do this now if I input the literal, i.e. public var myGlobalVar:String = "142";
The Web Service is attached, from Andrews' download. ValidateUser will only return boolean value.
Jim Faron
andrewj_ca
James,
Give this a try: new function called 'validatedUserInfo'.  It returns a string and has an addition input for 'returnColumn'.  Should work for you.
JamesFaron
Andrew,
Thank you for the script! It works perfectly.
Jim Faron
Austin Independent School District
