Attribute configured in popup not available in query widget
518
10-10-2019 11:16 AM
JulieBrown
I added an expression in my popup that simply makes one of the fields in the data uppercase (i.e. upper(field)). I added the expression to the fields that will display. If I click on a point in the map i see the result as expected, but in my web app builder app using the Query widget, when i try and use this attribute expression it isn't there. Also, when i run a query, the results don't include my attribute expression even though i say in the Results tab 'Use layer's pop-up configuration in the web map'
