Survey123 Inbox Order - ArcGIS Server Feature Service - Oracle DB
1153
10-02-2019 05:16 PM
Ohan_GeoDecisions
Case: A Survey123 published using an ArcGIS Server Feature Service reading from an Oracle Database.
In the Survey123 Mobile App, using Inbox has 2 options for Ordering:
  • A to Z
  • Time based
The ArcGIS Server Feature Service reading from an Oracle Database with Tracking Enabled adds the fields: CREATED_USER, CREATED_DATE, LAST_EDITED_USER, LAST_EDITED_DATE
The Time Based Ordering does not work based on LAST_EDITED_DATE
Any recommendations? or Future changes or workarounds ? James Tedrick Ismael Chivite‌
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Ohan,
Can you confirm that Editor Tracking is enabled and reported at the feature service endpoint?  If so, it sounds like there is a bug when working with your service.  It would be helpful if you could open a support ticket so the issue could be identified.
Ohan_GeoDecisions
Hello James,
Yes, i confirm that tracking is enabled, here is the service endpoint settings:
{"currentVersion": 10.41,"id": 0,"name": "blabla","type": "Feature Layer","description": "","copyrightText": "","defaultVisibility": true,"editFieldsInfo": {"creationDateField": "created_date","creatorField": "created_user","editDateField": "last_edited_date","editorField": "last_edited_user"},
and then a few lines down:
{"name": "CREATED_USER","type": "esriFieldTypeString","alias": "CREATED_USER","domain": null,"editable": false,"nullable": true,"length": 255},{"name": "CREATED_DATE","type": "esriFieldTypeDate","alias": "CREATED_DATE","domain": null,"editable": false,"nullable": true,"length": 8},{"name": "LAST_EDITED_USER","type": "esriFieldTypeString","alias": "LAST_EDITED_USER","domain": null,"editable": false,"nullable": true,"length": 255},{"name": "LAST_EDITED_DATE","type": "esriFieldTypeDate","alias": "LAST_EDITED_DATE","domain": null,"editable": false,"nullable": true,"length": 8},
We will create a ticket and follow this up, Thank you for your help
