Arcpy Script Field Calculator
5964
10
10-01-2019 07:36 AM
BrianMcNamara2
I am having issues getting a field calc script in arcpy to run. It's probably my parameters, but I can't seem to find the error. Please see below. I am 'ranking', one shapefile based on multiple columns (with weights applied). My goal is to import it as a script into a toolbox so a user doesn't have to use arcpy.
Thanks in advance!
Edit: format, spelling
#import system modules
import arcpy
import os
#set paramaters - parameters are weights
inFC = arcpy.GetParameter(0)
#fieldName_FinalScore = arcpy.ListFields(inFC)
Parameter_1_p = arcpy.GetParameter(1)
Parameter_2_p = arcpy.GetParameter(2)
#convert GetParamter to floats, I thought
Parameter_1 = float(Parameter_1_p)
Parameter_2 = float(Parameter_2_p)
#field name
fieldName_FinalScore = "FinalScore"
#lower box
expression_FinalScore = "Value(!Criteria1!,!Criteria2!)"
#code block upper
codeblock_FinalScore = """def Value( Criteria_1, Criteria_2):
FinalScore = !Criteria_1! * Parameter_1 + !Criteria_2! * Parameter_2"""
#Execute CalculateField
arcpy.CalculateField_management(inFC, fieldName_FinalScore, expression_FinalScore, "PYTHON_9.3", codeblock_FinalScore)
MicahBabinski
That helps! You're really close - we'll get ya sorted out. Assuming Criteria_1 and Criteria_2 are existing fields in your shapefile, I think you could ditch the codeblock parameter altogether and use something like this:
expression_FinalScore = """!Criteria_1! * {} + !Criteria_2! * {}""".format(str(Parameter_1), str(Parameter_2))
arcpy.CalculateField_management(inFC, fieldName_FinalScore, expression_FinalScore, "PYTHON_9.3")
As for your parameters, I believe that if you set the parameter type to "Double" in the script tool properties they will come in as the Python <float> type without any need to modify their types in the script.
Micah
JoshuaBixby
MVP Esteemed Contributor
Having issues?  It helps to provide specifics about the issues in addition to code.  Are you getting an error message?  if so, what?  Provide error and traceback.  Are you getting unexpected results?  If so, what?
Taking a quick look at the code, there are a couple issues with this line:
First, you don't put exclamation marks around the variables within a code block.  Second, you are defining a FinalScore variable but you are never returning it.  You have to return the value in order for the cursor to do anything with it.
BrianMcNamara2
Update below original thread, thank you so much for your reply!
JoeBorgione
Presenting your code in a more readable format is really helpful.  Below I've taken the liberty of clicking on the on the 'More' context menu in the expanded tool bar, and selecting Syntax Highlighter/Python and pasting your code there....  Joshua Bixby‌'s comment is directed to line #35.
import arcpy
import os
#field name
#lower box
#code block upper
BrianMcNamara2
Thank you for the reply and information, updated to make code more readable
MicahBabinski
What happens when you run the script, Brian McNamara‌? That will help pinpoint the answer.
As Joshua pointed out, you'll need to return the result of our Value() function. Put something like:
    return FinalScore
inside of those triple quotes.
Micah
BrianMcNamara2
Thank you for all the replies, I tried a few things that helped some, but not there. A new code is below that includes...
-Added return FinalScore (originally I had a syntax error, this seemed to solve that).
Notes:
-I'm not sure if the Parameter to float is needed, I read get parameter comes in as an object, does that mean a blob? That's why converted it (still investigating) .
-The error says 'not defined', so I assume its a scope issue. I'm trying to get the structure right for arcpy field calc. I think that's where my error is (still investigating)
#Geonet V2
import arcpy
import os
#set to float, not sure if GetParameter comes in as float, double or what. I read it comes in as an object (blob?)
#field name
#lower box
expression_FinalScore = "Value(!Criteria_1!,!Criteria_2!,Parameter_1,Parameter_2)"
#code block upper
codeblock_FinalScore = """def Value( Criteria_1, Criteria_2, Parameter_1, Parameter_2):
    FinalScore = Criteria_1 * Parameter_1 + Criteria_2 * Parameter_2
    return FinalScore"""
Error:
  File "W:\Citrix\35000s\35217\GIS\ExamplePropData\Rank\GeoNet.py", line 29, in <module>
  File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\management.py", line 3661, in CalculateField
    raise e
ExecuteError: ERROR 000539: Error running expression: Value(5.0,2.0,Parameter_1,Parameter_2)
  File "<expression>", line 1, in <module>
NameError: name 'Parameter_1' is not defined
Failed to execute (CalculateField).
Failed to execute (RankWeight2).
Failed at Tue Oct 01 12:51:12 2019 (Elapsed Time: 0.33 seconds)
MicahBabinski
Micah
BrianMcNamara2
That did it! Yes, Criteria_1 etc are existing fields. The format string did the trick, thank you so much for your help. I forgot about just using .format instead of the code block, I need to use python more consistently. Thanks again for your help.
final code is below
import arcpy
import os
Parameter_1 = arcpy.GetParameter(1)
Parameter_2 = arcpy.GetParameter(2)
#deleted set to float, no need as parameter comes in as double/float, via script properties
#field name
#lower box
#deleted code block
arcpy.CalculateField_management(inFC, fieldName_FinalScore, expression_FinalScore, "PYTHON_9.3")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
MicahBabinski
Glad to have helped, Brian McNamara. Happy scripting.
