Change Widget Settings from another Widget
3651
7
09-19-2019 12:21 PM
BrianLomas
I'm working on creating a widget that will pass settings to the TimeSlider. So, I'm wanting to configure the time extent from one widget and update the time slider extent (settings in image). I'm not sure if I can access those settings or how to do so. Any help would be appreciated. Thx
RobertScheitlin__GISP
Brain,
  It sounds like you are trying to over think this. From your widget you get a reference to the time slider widget. The widget object has a config property that is an object that is hydrated when the widget actual json file is read. So once you have the reference to the widget.config you just change the values using widget.config.customTimeConfig.startTime.time = x.
Brian,
   A widgets settings dialog just changes writes/edits value in that widgets config.json file. So you would just get a reference to the time sliders config and change it's values.
BrianLomas
These are the only setting in the config.json file...
"showLabels": false,
"autoPlay" : true,
"loopPlay": true,
"timeFormat": "auto"
Brain,
   The config.json file in the widgets folder is just the template for the real json file that is stored in the app configs/WIDGETNAME/XYZ.json file.
BrianLomas
I was able to find the mentioned config file here (to reference for others).
"...\WebAppBuilderForArcGIS-213\server\apps\4\configs\TimeSlider\config_widgets_TimeSlider_Widget_20.json"
So, my question is how do I access/update the json for the the "customTimeConfig.startTime.time" and the "endTime.timeConfig.time" properties through another widget? I'm also using the "_getWidgetConfig" function to open the TimeSlider already, if that helps.
Thanks for all the help.
  "autoPlay": false,
  "loopPlay": false,
  "timeFormat": "auto",
  "isHonorWebMap": false,
  "customLayersConfig": [
      "id": "[layer]",
      "isTimeEnable": true
  "customTimeConfig": {
    "keepValueFlag": false,
    "startTime": {
      "timeConfig": {
        "timeMode": "min",
        "time": 1567191360000,
        "calender": {
          "operator": "",
          "number": "",
          "unit": ""
    "endTime": {
      "timeConfig": {
        "timeMode": "max",
        "time": 1568901360000,
        "calender": {
          "operator": "",
          "number": "",
          "unit": ""
    "interval": {
      "number": 2,
      "units": "esriTimeUnitsDays"
    "displayAllData": false
  "customDateFormat": ""
Brain,
BrianLomas
As usual, you came through again. Thanks for the quick responses and the help on this, it's greatly appreciated.
BrianLomas
Is this the reference you are talking about? This was located in the "ConfigureTimeSettings.js".
timeConfigFromat = {
startTime:{
timeConfig: TimeCalendar.config
endTime:{
interval:{
number: null //number
units:""//esriTimeInfo.X
displayAllData: false//t / f
// postCreate: function () {
// this.inherited(arguments);
