ODCostMatrix Lines output is empty using arcpy.nax?
1090
08-30-2019 06:52 PM
PrestonSahabu
After reading through the documentation of the new arcpy.nax library, specifically ODCostMatrix and related objects, I attempted to port over a script that was using arcpy.na. Unfortunately the Lines output remains stubbornly blank using mostly default inputs, and I am having trouble diagnosing why that is. I've tried changing several of the inputs but none of them seem to fill the Lines output.
Here is the portion of my script using ODCostMatrix:
od = arcpy.nax.OriginDestinationCostMatrix(NETWORK)
od.distanceUnits = arcpy.nax.DistanceUnits.Meters
od.defaultDestinationCount = 1
# CENT_TEMP is a feature class of points, drawn from the centroids of polygons
# DESTS is also a feature class of points
od.load(arcpy.nax.OriginDestinationCostMatrixInputDataType.Origins, CENT_TEMP)
od.load(arcpy.nax.OriginDestinationCostMatrixInputDataType.Destinations, DESTS)
od_result = od.solve()
arcpy.management.Delete(CENT_TEMP)
# later on in the code...
orig_dist = {}
line_search = arcpy.nax.OriginDestinationCostMatrixOutputDataType.Lines
OD_LINES = arcpy.env.workspace + r"/od_lines"
od_result.export(line_search, OD_LINES)
with arcpy.da.SearchCursor(OD_LINES, ["OriginOID", "DestinationOID", "Shape_Length", "Total_Distance"]) as sCursor:
    # ... does not work because OD_LINES is empty
Here is the description of my network. It was a pre-existing network, and I added the "Basic" travel mode so it would work with arcpy.nax.
Data Type: File Geodatabase Network Dataset
Database:
  [REDACTED]
Feature Dataset: RDIDataSet1
Network: RDINetwork1
Dataset Version: 10.0
Build Status: Built
  The network dataset has been built.
  Build Time: Fri Aug 30 18:39:27 2019
  Edges: 5460
  Junctions: 2179
Sources:
  Edge Sources:
    Streets1
  Junction Sources:
    RDINetwork1_Junctions
Connectivity:
  Policies:
    Streets1 edges use End Point connectivity policy.
  Elevation Model: Elevation Fields
Travel Attributes:
  Travel Modes:
    Default Travel Mode: Basic
    Travel Mode: Basic
      Description:
        Collection of network dataset settings that define actions that are allowed on the
        network and how the actions can be performed.
      Type: Automobile
      Uses Costs:
        Impedance: RouteDistance
      Allowed U-Turns: All
  Costs:
    Cost: RouteDistance
      Units: Meters
      Data Type: double
      Used By Travel Modes:
        Impedance: Basic
      Evaluators:
        Streets1 (Bi-Directional): Field Script (VBScript)
          Value: [Shape_Length]
The full script is attached. Any help is appreciated!
